Engine Performance problem
2002 Ford Excursion
Hello, first-time user here. I thought I'd try a little mileage-improving gizmo I found on eBay. It looks like a small resistor, and it's supposed to go between the 2 wires that otherwise would connect to the intake air temperature (IAT) gauge. The directions say to look for a small, 2-wire plug on or near the intake manifold. They also talk about what to do if you find a plug with "four or five" wires.
Naturally, my situation doesn't match either of these. I found one 3-wire plug attached to the throttle area that has a gray wire with a red stripe, a gray or green wire with a white stripe, and a brown wire with a white stripe, in that order. There is also a 6-wire plug (more of a large rubber stopper, actually) on the air filter housing with the following wires, in order:
Gray with white stripe
Solid red
Black with white stripe
Orange with blue stripe
Blue with red stripe
Solid gray
(Note: the wires are all pretty dusty, so I can't be 100% sure of these colors.)
Any idea which of these wires are the two IAT wires?
Thanks,
Duane
p.s. FWIW, the gizmo comes from Innovated Engineering of Clearwater, Florida.
2002 Ford Excursion
Solid red
Solid gray
Thanks,
Duane
Feb 28, 2009 at 3:14 PM
