trun signals not working, have replaced all the bulbs. can not locate fuse or relay
Nov 13, 2009 at 1:15 PM
JDL
CERTIFIED EXPERT
Welcome to the forum, check fuse 27, 15 amp in central junction box. Not only check fuse, use a testlite on the fuse circuit, it should go hot when you turn on the key. That circuit is voltage for the turn signal.
