2001 Ford Excursion Wont start
2001 FORD EXCURSION
76,532 MILES • V8 • 2WD • AUTOMATIC
ALFREDRENTERIAJR
Hi, I have a 2001 frod excursion V10 run good once it is started and no problems runing, problem starting, good battery, fuel line is presered, wont start right away, i have to turn key to on for a min or two, turn off, press gas pedial then start sometimes, I went on another site and paid, I was told to replace the iac valve but that did not work.
Mar 18, 2009 at 1:47 PM
have you actually checked the fuel pump pressure? Also, when it doesn't start, have you checked to see if it is getting spark?
Jun 20, 2009 at 10:00 PM
