2000 Ford Excursion trouble codes
2000 FORD EXCURSION
BARBER
My Excursion has 195184 miles on a 7.3L TD PowerStroke. I have two dtc (codes) that I would like to try to pinpoint and repair if I can. The first is P0674 and the second is P0107. What do you recommend be done to correct these problems? Thank you!
Dec 28, 2006 at 11:44 AM
INDYUKE
  • 416 POSTS
P0107 - Manifold Absolute Pressure / Barometric Pressure circuit low input. Possibly a loose or broken wire between the computer and the MAP sensor. Maybe a bad MAP sensor?
I don't know what the code P0674 means.
Jan 1, 2007 at 7:36 PM
