2000 Ford Excursion caliper removal
2000 FORD EXCURSION
CHIK4HIC
Brakes problem
2000 Ford Excursion Four Wheel Drive Automatic 18000 miles
I can not get my caliper pin to losen up. I don't want to strip it out, and don't have enough room to get the impact in to use it.
Jul 13, 2010 at 12:36 PM
BLACKOP555
  • 10,386 POSTS
turn the wheel put a larger breaker bar on it and a pipe. or you can choose to heat up the caliper mounts where the threads are and then try to brake it loose. dont get the mounts to hot and damage the rubber.
Jul 13, 2010 at 6:40 PM
