valve location
FORD ESCORT
WILLIAMHAUSERMAN
Where will I find the valve to drain the coolant/antifreeze from my radiator on my 93 ford escort, 1.9 l, 170,000 miles?
Aug 10, 2007 at 5:11 PM
[quote:a86237c0a1="williamhauserman"]Where will I find the valve to drain the coolant/antifreeze from my radiator on my 93 ford escort, 1.9 l, 170,000 miles?[/quote:a86237c0a1]
I'll guess on this normally they are on the bottom of the radiator L/R corner. or you can just disconnect the bottom hose to drain it, then put it back run a flush, disconnect it again let drain,put it back on then put your coolant and your done.
Aug 12, 2007 at 5:51 PM
