1995 ford escort sport lx 180,000 im thinking the problem can be, the [b:9f5acfc132]ignition control module[/b:9f5acfc132]?
let me remind you what is happening and what ive gone:
[i:9f5acfc132]here is the problem i have with it as of this morning:
i start it up, and it just dies, it stays running for 10 seconds, then shuts off. here is what i have done:
1)changed the air filter
2)changed the fuel filter
3)changed the fuel pump
4)changed the o2 sensor
5)changed out with a used MAS
6)changed out with a used IAC (both from pick n pull)
8)new gaskets in all the necesary parts[/i:9f5acfc132]
and have gone and [b:9f5acfc132]taped up all the hoses[/b:9f5acfc132], and changed small parts on things such as on the mas air flow boot thing, what else is there left to change?
although now, when[b:9f5acfc132] before [/b:9f5acfc132]it was [b:9f5acfc132]difficult to keep running, low idle , stalling[/b:9f5acfc132] out on me, [b:9f5acfc132]now[/b:9f5acfc132] it is just [b:9f5acfc132]hard to start[/b:9f5acfc132], but when it starts [i:9f5acfc132][b:9f5acfc132]generally[/b:9f5acfc132][/i:9f5acfc132] doesn't idle rough anymore, and doesn't stall. generally. its running at 60%.
Dec 18, 2006 at 12:04 PM
