Ford Escort SE 1998;
164,000 mi.;
Stick shift;
2 wheel (front) drive;
noise in front left side when stopping with brakes;
no leaks;
new rear springs, shocks, brakes; new left front tie rod (Noise started before tie rod replacement);
When I come to a stop a repeating grinding noise occurs near the left front tire; With the car on a jack, the left front tire has excessive play when I rotate it forward and backward (more play than the right front side); there is no excessive play when I attempt to turn the tire to the left or right.
Is the problem a cv joint? Thanks for youir advice.
164,000 mi.;
Stick shift;
no leaks;
Jun 19, 2007 at 7:00 PM
