I havea 1994 ford escort, i put it though an emissions test and it fail the nox the limit was 583 admy reading was 702, the codes where egr valve opening not present and throttle positioning sensor, i changed the oil and filter, spark plugs and cleaned out with throttle body cleaner stil nothing, the readings were the same, i changed the egr soliiod but still nothing, the egr valve opens if i put direct vaccum on it but doesn't seem to work the way it should can you give me any suggestions, or tell me how to check the egr valve, soliod and such. thank you
Apr 12, 2007 at 8:20 PM
