Clutch Limit Switch-'94 Ford Escort-148K Miles
1994 FORD ESCORT
WEEKEND MECH
1994 ford Escort - 148K miles- Sometimes I have to depress clutch 2-3 times before engine will start.Should I replace the clutch limit switch and where is it located?
Thanks!
Apr 25, 2006 at 9:19 AM
LOSONE
  • 1,616 POSTS
It is adjustable and located in the top area of the clutch area. It is not a limit switch but a safety switch so it cannot be started in gear. Easy to replace if you are 3' tall and have 2" diameter arms.
Apr 25, 2006 at 11:35 AM
WEEKEND MECH
Is the "clutch area" you mentioned near the top of the clutch pedal area or is the safety switch under the hood at the rear of the engine.
Thanks.
Apr 25, 2006 at 1:46 PM
LOSONE
  • 1,616 POSTS
under the dash on top of the inside clutch pedal assy.
Apr 25, 2006 at 2:20 PM
