1995 Ford Escort 1.9L engine, 128,000 miles. The A.C. clutch engages for 3 seconds then disengages. I bypassed the clutch cycling swith and the problem still occurs. There is a relay on the firewall I can here clicking. Would that be the problem?
Freon is fine, however I tested the wire that goes to the AC clutch at the relay, it tested fine. Checked at the clutch and my test light stays on even when the clutch kicks out. Would this be a short between the relay and the AC clutch?
Aug 16, 2007 at 8:23 AM
