91/92 Ford Escort Wagon won't turn over
1991 FORD ESCORT
ZOJILA
Thank you in advance for your help! My "built in 91" Ford Escort Wagon (not sure of the mileage, it's at home and I'm at work, but it's lower than the usual mileage for a car of this age) won't turn over/start. I put in the key and turned it. Nothing. When it would normally take a little more effort to turn the key, it was soft, it didn't "catch" at the end where it was supposed to actually turn on the car. I am not explaining this very well, sorry- I am a girlie girl. The car made no noise at all when I tried to start it. My radio came on and I can turn on the headlights. All my dashboard warning lights came on and stayed on even after I removed the key. I tried again and again, nothing. I have had no other problems with this car recently, and I take care of it (maintenance) like I'm supposed to! What could be the problem? Thank you!
Nov 12, 2007 at 11:54 AM
2CARPRO JACK
  • 11,533 POSTS
Could be the starter. Try starting it in neautral, if it works then it is most likely the neutral safetyy switch. If it doesnt crank, then it is most likely the starter.Test for power atthe small wire on the starter with key in crank position, if there is power and no start, replace starter
Dec 14, 2018 at 9:36 AM
ZOJILA
I had my car towed to my mechanic, it was the ignition switch. My husband diagnosed it from the "soft" key turning, and the mechanic confirmed it. He replaced it and now it runs great again. Thanks for tryin'!
