My 4 way flashers(emergency flashers) isn't working. At first both the directionals and 4 way flasher stopped wokring. Replaced fuse, flasher, directional switch, flasher switch, traced wires etc. All work done by cerified ASE mechanic . Problem was not located . Mechanic stated by luck, unknown what he did or touched the directionals began to work, but 4 way flashers still not working, Anything you can suggest to do? Mechanic cannot located problem through hours or tracing wires and replacing all obvious parts. Thanks
Aug 24, 2007 at 1:18 AM
