Ive changed both ect`s ,thermostst and I still get a po125 code. after about a day. do u have any ideas?
Jul 26, 2009 at 7:07 PM
LAZYGAZER
MEMBER
Code P0125 is Insufficient coolant temperature for closed loop fuel control.
This could be that the coolant is not getting to specs for normal operation,your coolant temp. sensor could be faulty sending wrong info to the EEC. Also check for coolant flow.
Aug 2, 2009 at 8:11 PM
ACERS30
MEMBER
thanks for the info. I`ll try to change both sensors..
