It ran before-backtrack all wiring connectors that you have unplugged-also you need a ignition module tester to check the ICM
The CPS tracks the position of the pistons and engine speed sends it to the computer and in turn fire the coils
One way to check if the DIS ignition module and its crankshaft sensor circuit are working: connect a halogen headlamp to the spade terminals that mate the DIS module to the coils. A headlamp is recommended here because it puts more of a load on the module than a test lamp. If the headlamp flashes when the engine is cranked, the DIS module and crankshaft position sensor circuit are functioning. Therefore, the problem is in the coils.
If the headlamp does not flash, or there is no voltage to the module or coil pack when the engine is cranked, the problem is most likely in the crankshaft sensor circuit. On most vehicles, a bad crank position sensor will usually set a fault code, so use a scan tool to check for a code. Or, check the crank sensor itself.
Jan 23, 2010 at 5:33 PM
