Rear brake adjustment
2001 FORD ESCORT
96,000 MILES • 4 CYL • FWD • AUTOMATIC
HAYESMAN
How do I adjust the rear brake shoes closer to the brake drums?
Aug 13, 2008 at 2:15 PM
BMRFIXIT
  • 19,053 POSTS
PARKING BRAKE
NOTE: Parking brake is self-adjusting on Contour and Mystique. To adjust, operate parking brake several times.
Escort
1.Count number of notches it takes to fully apply parking brake lever. If parking brake is fully applied, 5-7 notches, parking brake adjustment is okay. If parking brake requires adjustment, go to next step.
2.Parking brake cable is adjusted at parking brake lever. Remove center console. Ensure parking brake is fully released. Tighten adjusting nut at parking brake lever until adjustment is within specification. Install center console. Check parking brake operation.
REAR BRAKE SHOES
1.This adjustment should be made only after replacing brake lining or if brake applications are insufficient to actuate automatic adjuster. Raise and support vehicle. Remove wheels.
2.Remove brake drum. Using a brake drum diameter gauge, determine brake drum diameter and proper shoe diameter. Hold automatic adjusting lever out of engagement. Using a screwdriver, rotate knurled quadrant on adjuster assembly to adjust brake shoes.
3.Adjust brake shoes to fit gauge. Rotate gauge around shoe to ensure proper fit. Install brake drum. Install wheels. Check brake operation by making several stops at varying forward speeds.
The guide below will give you an idea of how to adjust them, not vehicle specific,but same principle
https://www.2carpros.com/articles/parking-brake-shoe-replacement
See pics attached below
Aug 13, 2008 at 5:19 PM
HAYESMAN
How do I adjust the rear brake shoes up to make contact with the brake drums?
Dec 8, 2018 at 11:24 AM (Merged)
BLACKOP555
  • 10,386 POSTS
put on the parking brake a few times and release.
then drive in reverse on a flat dry surface adn stop moderatley then fastly then the brakes are all set.
KFUT
how does rear brakes self adjust 1997 ford escort
Use a brake gauge to save time, unavailable -you need to adjust until they just clear the drum (little or no drag felt when the drum is rotated after initial adjustment do a few reverse braking to self adjust
STEVECHASE19
It does not answer the question asked. Not even close.
Dec 28, 2018 at 11:32 AM
