2000 Ford Escort turns over but wont start
2000 FORD ESCORT
TONYR1987
Engine Mechanical problem
2000 Ford Escort 4 cyl Front Wheel Drive Automatic
im trying to help someone they have a frd escort 2.0 4 door... the engine will turn over but wont start its got spark and i do beleave it has fuel.. and has air im going to go make sure its getting fuel today but if it is ,what other things should i look for or check for to as of why it wont crank over... before it stoped it would idle but had no pedal .cables good.she pulled it over and it started over heating n she shut it off then this problem presented it self wont start .. we replaced the head gasket and it solved the pronlem or compression into the radiator but looked and everything was fine but still the problem is still promanent please help.........
Apr 24, 2010 at 1:30 PM
Check the fuel pressure if its within specs and also for injection pulses.
Apr 24, 2010 at 5:50 PM
