2000 Ford Escort PCV VALVE
2000 FORD ESCORT
156,000 MILES • 4 CYL • FWD • AUTOMATIC
SCHNIDER89
I was wondering if changing the PCV valve really helps and also where is it located I have the ZX2 model with the DOHC engine. It idles very rough and it is very annoying almost acting like it should die but doesnt. What can I do to help this problem?? I dont feel like wasting my time at a mechanic.
Jan 31, 2010 at 9:57 PM
KIMMFREI
[quote:85d06f7b5f="schnider89"]Engine Performance problem
2000 Ford Escort 4 cyl Front Wheel Drive Automatic 156000 miles
I was wondering if changing the PCV valve really helps and also where is it located I have the ZX2 model with the DOHC engine. It idles very rough and it is very annoying almost acting like it should die but doesnt. What can I do to help this problem?? I dont feel like wasting my time at a mechanic.[/quote:85d06f7b5f]
It does help to change the valve (but don't change it everytiime you change the oil like some shops try to sell you) as for the location looking at engine on the right hand side of the exhaust manifold, there is a hose and at the end of the hose is the valve. Good luck and I hope this helped
Feb 4, 2010 at 4:53 PM
