Today, my car died. would start back up but will not run all on all cylinders. Plugs ok, wires new, have fire to 2 plugs but dead on other 2 plugs. Bought new coil, still have same problem.
Before problem started, had rough idle. Engine light came on, code suggested oxygen sensors. Bought new sensors. Light came back on after resetting memory, suggested same thing.
Prior to this, a/c clutch stopped working, system good and fully charged. Hot wire hooked to clutch air goes ice cold.
I am mainly questioning ignition coil problems, but tossed extra info in to help if there may be a connection to all. Good luck
Sep 1, 2009 at 8:13 PM
