2000 Ford Escort camshaft position sensor
2000 FORD ESCORT
100,000 MILES • 4 CYL • FWD • MANUAL
DANKWEED432004
my car dies after you let off the gas it will start right back up but when i let off gas and when i stop it dies i put the scanner on it it says it is a po340 i belive wich is the cam shaft pos sensor could it be somthing other than that or does it sound like that is my problem this just started doing this last night
Mar 21, 2008 at 2:50 PM
Check your idle air control motor and thorttle position sensor-
P0340 OBD-II Trouble Code
Technical DescriptionCamshaft Position Sensor Circuit Malfunction
What does that mean?This indicates that a problem was detected in the camshaft position sensor circuit. Since it says circuit, that means the problem could lie in any part of the circuit - the sensor itself, the wiring, or the PCM. Don't just replace the CPS (camshaft position sensor) and think that will definitely fix it.
Symptoms can include:
Hard starting or no start
Rough running / misfiring
Loss of engine power
Causes A code P0340 could mean one or more of the following has happened:
a wire or connector in the circuit could be grounded/shorted/broken
the camshaft position sensor may have failed
the PCM may have failed
there exists an open circuit
the crankshaft position sensor may have failed
Possible Solutions
With a P0340 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
Visually inspect all the wiring and connectors in the circuit
Check for continuity in the circuit wiring
Check the operation (voltage) of the camshaft position sensor
Replace the camshaft position sensor as required
Check the crankshaft position circuit as well
Replace circuit wiring and/or connectors as required
Diagnose/replace the PCM as required
Mar 21, 2008 at 5:35 PM
