1999 Ford Escort Will'nt start at times
1999 FORD ESCORT
13,000 MILES • 4 CYL • FWD • AUTOMATIC
LEDZEPZOSO04
Engine turns over but will not start at times plenty of fuel but engine will not kick in. After sitting awhile if you push and hold pedal to the floor it will start. Seems like engine is not getting fuel. When you turn the key you can hear the fuel pump click on. Used fuel injecter cleaner but does not help.
Sep 15, 2009 at 7:29 AM
LAZYGAZER
  • 68 POSTS
check for fuel pressure. There should be a valve on the fuel rail for the injectors, a rough check is to turn the switch to on then depress the valve with something appropriate not to damage it. see how forceful is the pressure if its low your pump is weak if its high then its probably your spark let us know.
Sep 16, 2009 at 5:12 AM
MEDIC01543
[quote:88713adcf5="ledzepzoso04"]Engine Mechanical problem1999 Ford Escort  4 cyl Front Wheel Drive Automatic 130,00 milesEngine turns over but will not start at times plenty of fuel but  engine will not kick in. After sitting awhile if you push and hold pedal to the floor it will start. Seems like engine is not getting fuel. When you turn the key you can hear the fuel pump click on. Used fuel injecter cleaner but does not help.[/quote:88713adcf5]
change the spark plugs...after that change the oil and filter
Sep 16, 2009 at 5:48 AM
