1999 Ford Escort vehicle turns off when slowing down, only
1999 FORD ESCORT
14,000 MILES • 4 CYL • FWD • AUTOMATIC
CHACHO
1999 ford escort vehicle turns off when slowing down, only when a/c is on? trouble code p0302, have replaced timing belt/tensioner, reset timing three times also replaced iac, tps, new plugs gaped to .54, replaced all vacume lines found no other leaks new fuel filter good presure, cleaned throtle plate, new air filter, spark on all four wires. car runs smooth with good power. ? i have hit a wall.
Jun 14, 2008 at 5:26 PM
BMRFIXIT
  • 19,053 POSTS
Check crankshaft pulley
check crank pulley and pulse ring for damage or looseness
check crank sensor
Jun 15, 2008 at 7:44 AM
