1999 Ford Escort Timing belt questions on the 2.0 SOHC
1999 FORD ESCORT
122,700 MILES • 4 CYL • FWD • AUTOMATIC
IRFMAN2000
  • 32 POSTS
I'm planning on replacing the timing belt myself when the weather breaks. My question is when installing the new belt how do I put it on without moving the camshaft?? I did read that its supposed to installed at the crank 1st and the other pulleys. That's my biggest fear since I don't want to throw it out of time. If I do mistakenly move it does it matter which way I turn the cam to reline it??
Another question is the tensioner is spring loaded like the drive belt tensioner?? I read up that you can move it with a allen wrench without loosening the bolt and put the drill bit in to keep it in place.
Last question is when I take off the crankshaft pulley, will the engine turn to the left a little?? I keep hearing that if you turn it that way, it can cause damage. When I do get the pulley off, can I put the bolt back in to line up the marks??
This is my 1st time ever doing a timing belt since i'm mechanically inclined on most other general repairs so that's why i'm asking all of these questions.. Thanks in advance.
Jan 24, 2009 at 2:03 PM
BILLYMAC
  • 2,204 POSTS
hi ,this is simple .first line the marks up mark them with white paint or yellow.next remove the accessory belts a/c p/s alt.remove the crank pulley put the bolt back in the crank.line the marks back up.release the tensioner.remove the timeing belt.install new one crank first put the slack in the belt on the tensioner side release the tensioner. turn eng over{BY HAND} 2 OR THREE REVOLUTIONS.TIGHTEN THE TENSIONER .put bottom cover on and crank pulley check marks one more time. start eng if runs normal. install the rest of the parts... good luck billymac
Jan 24, 2009 at 2:14 PM
IRFMAN2000
  • 32 POSTS
[quote:1b0852a5b6="billymac"]hi ,this is simple .first line the marks up mark them with white paint or yellow.next remove the accessory belts a/c p/s alt.remove the crank pulley put the bolt back in the crank.line the marks back up.release the tensioner.remove the timeing belt.install new one crank first put the slack in the belt on the tensioner side release the tensioner. turn eng over{BY HAND} 2 OR THREE REVOLUTIONS.TIGHTEN THE TENSIONER .put bottom cover on and crank pulley check marks one more time. start eng if runs normal. install the rest of the parts... good luck billymac[/quote:1b0852a5b6]
Damn that was a fast repsonse. Thanks again for it. So I won't damage the engine by turning it clockwise while removing the crankshaft bolt huh? If that's the case thats a good thing.
On the tensioner, I thought it is an auto tensioner like the drive belt one. I found out that you can just use the allen wrench to turn it without loosening the bolt and put the bit in to lock it. I also saw in haynes that the spark plugs have to be taken out. From what I see, people skip that step.
Jan 24, 2009 at 2:30 PM
IRFMAN2000
  • 32 POSTS
[quote:b4807e16b3="irfman2000"][quote:b4807e16b3="billymac"]hi ,this is simple .first line the marks up mark them with white paint or yellow.next remove the accessory belts a/c p/s alt.remove the crank pulley put the bolt back in the crank.line the marks back up.release the tensioner.remove the timeing belt.install new one crank first put the slack in the belt on the tensioner side release the tensioner. turn eng over{BY HAND} 2 OR THREE REVOLUTIONS.TIGHTEN THE TENSIONER .put bottom cover on and crank pulley check marks one more time. start eng if runs normal. install the rest of the parts... good luck billymac[/quote:b4807e16b3]
On the tensioner, I thought it is an auto tensioner like the drive belt one. I found out that you can just use the allen wrench to turn it without loosening the bolt and put the bit in to lock it. I also saw in haynes that the spark plugs have to be taken out. From what I see, people skip that step.[/quote:b4807e16b3]
Oh yea two more question, when I replace the water pump, is it easier to remove the tensioner?? And is the camshaft easy to move(like spinning freely like a wheel)?? Like I said I don't want to throw the cam out of time. Thanks again.
Jan 24, 2009 at 2:34 PM
BILLYMAC
  • 2,204 POSTS
yes you will not hurt the eng by looseing the bolt however you will have to hold the eng to loosen that bolt anyway an impact works great for that. yes i take the tensioner off to replace the pump. no the cam does not spin freely valves open and close it will not spin by itself and if you mark it from the beginning you never have to worry. although eng damage is not likely with this eng and all overhead cam engs. you must use caution.the spark plugs ..yes the proper way is to remove the spark plugs.and no i don,t if any at all just the number one..so i can make sure it is on compression stroke..hope this helps billymac
Jan 24, 2009 at 8:44 PM
IRFMAN2000
  • 32 POSTS
[quote:058210cec0="billymac"]yes you will not hurt the eng by looseing the bolt however you will have to hold the eng to loosen that bolt anyway an impact works great for that. yes i take the tensioner off to replace the pump. no the cam does not spin freely valves open and close it will not spin by itself and if you mark it from the beginning you never have to worry. although eng damage is not likely with this eng and all overhead cam engs. you must use caution.the spark plugs ..yes the proper way is to remove the spark plugs.and no i don,t if any at all just the number one..so i can make sure it is on compression stroke..hope this helps billymac[/quote:058210cec0]
Billymac. Thanks for answering all of my questions. I really do appreciate it. I think I feel more confident doing the job.
So the cam takes almost as much resistance to turn as the crankshaft right?? You told me they are turned by the valves.
You didn't answer the question on the tensioner lol. Is it automatic(springs back and forth like th drivebelt one)?? Like I said I keep reading that it is and you told me that I have to loosen the bolt to move it so i'm confused. Thanks again. I hope i'm not driving you crazy with this lol.
Jan 25, 2009 at 3:04 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Hi irfman2000, billymac gave you great info and good advise. Just thought I'd through in some Removal and Install instructions along with a couple pic's to help out. Press your "CTRL" and the "+" key to zoom in for better reading...
https://www.2carpros.com/forum/automotive_pictures/188069_99escorttimingbeltremove_1.jpg
https://www.2carpros.com/forum/automotive_pictures/188069_99escorttimingbeltinstall_1.jpg
Fig 1
https://www.2carpros.com/forum/automotive_pictures/188069_99escorttimingmarks_1.jpg
Fig 2
https://www.2carpros.com/forum/automotive_pictures/188069_99escorttimetensioner_1.jpg
Jan 25, 2009 at 3:23 PM
IRFMAN2000
  • 32 POSTS
Hey obxautomedic thanks for the reply but i've already read and studied the book but all I needed to know is that when I take off the belt if I can just turn the tensioner pulley with the allen wrench without loosening the bolt? That's what I keep reading up on. It never said to loosen the bolt according to the haynes manual. So I guess its not an automatic tensioner huh??
Jan 25, 2009 at 3:33 PM
OBXAUTOMEDIC
  • 3,711 POSTS
No, you will have to loosen the tensioners....
Take a look at my post above at the remove pic.
Jan 25, 2009 at 3:47 PM
IRFMAN2000
  • 32 POSTS
Yea I understood the print you sent me but I keep reading that it is spring loaded. In that case why does it say to stick a drill bit or something thin to hold it back? Shouldn't stay back by itself since you gotta loosen the bolt anyway?? it if doesn't stay back by itself should I mark where it was originally at then remove it?? Sorry i'm just trying to get this straight here since the timing belt thing is new to me.
Oh yea on the camshaft, it does take a lot to move right?? I just dont want to throw that part out of time when I slip the new belt on. Thanks again.
Jan 25, 2009 at 3:55 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:f84dbcd61d="irfman2000"]Yea I understood the print you sent me but I keep reading that it is spring loaded. In that case why does it say to stick a drill bit or something thin to hold it back? Shouldn't stay back by itself since you gotta loosen the bolt anyway?? it if doesn't stay back by itself should I mark where it was originally at then remove it?? Sorry i'm just trying to get this straight here since the timing belt thing is new to me.
Oh yea on the camshaft, it does take a lot to move right?? I just dont want to throw that part out of time when I slip the new belt on. Thanks again.[/quote:f84dbcd61d]
Yes, it is spring loaded, No the tension when you loosen the bolt the tension goes in the direction of the belt making it tighter.
No, you don't want to mark it. With the new belt it may make it to tight or to loose. Not all belts are exactly the same size and that it why a tensioner was put there.
As far as the Cam movement, it doesn't take as much to turn it as is does for the Crank. You can move it with your hands, It gets hard once it opens a Valve. If you move it around a little (Clock Wise or Counter Clockwise) it will not hurt anything.
Also, since you will be there already are you planning on replacing the Water Pump.
Here is one thing you can do....
Before putting it all back together. You can start the vehicle just Don't Run it more than 5 -10 seconds. Do make sure your radiator hoses are connected. And have someone start it for you while you watch the timing belt because it does have a tendency to walk off since the cover is not there to keep it in place.
And to be honest they can be a pain getting back on you will just have to work it.
Jan 25, 2009 at 9:54 PM
IRFMAN2000
  • 32 POSTS
[quote:68333a12cb="obxautomedic"][quote:68333a12cb="irfman2000"]Yea I understood the print you sent me but I keep reading that it is spring loaded. In that case why does it say to stick a drill bit or something thin to hold it back? Shouldn't stay back by itself since you gotta loosen the bolt anyway?? it if doesn't stay back by itself should I mark where it was originally at then remove it?? Sorry i'm just trying to get this straight here since the timing belt thing is new to me.
Oh yea on the camshaft, it does take a lot to move right?? I just dont want to throw that part out of time when I slip the new belt on. Thanks again.[/quote:68333a12cb]
Yes i'm planning on doing the water pump also. I do see a little oil on the bottom of the timing cover so I might possibly need a crankshaft seal too. Is the crank sprocket easy to get off?? I figured i'd do as much as I can while i'm in there becuase i'm not tearing the shit down again lol because of something I didn't do.
Back on the tensioner subject do you usually change it?? I know some people don't but I heard its recommended. When I put it back on and tighten the bolt after taking the bit out, it won't put a lot of tension on the belt right?? I know the tension is critical on a belt.
Thanks again for the reply. Damn you guys are great lol.
Jan 25, 2009 at 10:26 PM
BILLYMAC
  • 2,204 POSTS
hold tensioner out of the way while you replace belt. YOU HAVE TO LOOSEN BOLT. the bolt makes sure the tensioner does not kick back,.haynes manual is not descriptive enough to explain this. thanks. car pro tech thanks for your input billymac
Jan 26, 2009 at 8:37 AM
IRFMAN2000
  • 32 POSTS
[quote:387ff58105="billymac"]hold tensioner out of the way while you replace belt. YOU HAVE TO LOOSEN BOLT. the bolt makes sure the tensioner does not kick back,.haynes manual is not descriptive enough to explain this. thanks. car pro tech thanks for your input billymac[/quote:387ff58105]
Ok cool. Thanks gentlemen for answering all of my questions on this job. I greatly appreciate it. Haynes sucks balls. I know I should've went ahead and stil got a chiltons. One more question and this will be it, should I still replace the tensioner though?? With the kind of mileage I have on it do you think it'll be still good??
Jan 26, 2009 at 6:31 PM
BILLYMAC
  • 2,204 POSTS
hi again yes always a good idea to replace tensioner water pump. and no prob we are happy to help anytime. the only stupid question is the one that wasn,t asked good luck billymac
Jan 26, 2009 at 8:10 PM
IRFMAN2000
  • 32 POSTS
[quote:14c7757a8b="billymac"]hi again yes always a good idea to replace tensioner water pump. and no prob we are happy to help anytime. the only stupid question is the one that wasn,t asked good luck billymac[/quote:14c7757a8b]
Well thanks agin, now I feel more confident on doing the job now. It won't be until the weather breaks like march or no. Too damn cold to do it and I want plenty of light to do it instead of doing it in a garage.
Jan 26, 2009 at 8:15 PM
IRFMAN2000
  • 32 POSTS
I did say I do have a little oil on the bottom of the the timing cover and possibly might need a crankshaft seal. How hard is it to replace it and to remove the sprocket? Thanks. Ok promise no more questions on this thread after this lol.
Jan 26, 2009 at 8:20 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:4415136fd5="irfman2000"]I did say I do have a little oil on the bottom of the the timing cover and possibly might need a crankshaft seal. How hard is it to replace it and to remove the sprocket? Thanks. Ok promise no more questions on this thread after this lol.[/quote:4415136fd5]
The spocket should pull off without problem. And you should be able to pry the seal out with a flat head screw driver, cause it won't matter if you tear it up.
And hate to burst your bubble but Haynes bought out Chilton a few years ago.
And also ask as many questions as you need in order to get the job done. Thats is what we are here for.
Even if it takes a hundred or more posts to get there.
Good luck and let us know how you do...
Jan 26, 2009 at 9:48 PM
IRFMAN2000
  • 32 POSTS
[quote:718a0374e5="obxautomedic"][quote:718a0374e5="irfman2000"]I did say I do have a little oil on the bottom of the the timing cover and possibly might need a crankshaft seal. How hard is it to replace it and to remove the sprocket? Thanks. Ok promise no more questions on this thread after this lol.[/quote:718a0374e5]
Wow, i didnt know haynes bought out chiltons. Good to know lol. Thanks a lot for that. But anyways so the sprocket just pulls straight out?? How hard is it and what the best way to do it?? It wouldn't throw off the timing right?? Thanks again in advance.
Jan 26, 2009 at 9:56 PM
OBXAUTOMEDIC
  • 3,711 POSTS
You may need to pry it a little with a flat screw driver, but should come off very easily. No it won't throw off timing it will only go on one way.
Jan 26, 2009 at 10:37 PM
IRFMAN2000
  • 32 POSTS
oh ok. I thought the sprocket was held on by a tork or an allen bolt and had to be pulled off with a tool. But I didn't know it's easy to take off by just pulling it off.
Jan 27, 2009 at 4:49 AM
IRFMAN2000
  • 32 POSTS
Well sorry it took so long to respond back but I was waiting until the weather breaks and its gonna be 80 degrees tomorrow and ill be working on the car. Wish me luck on it. I'll let you know how it goes.
I do have a question, on the brank pulley it should just come right off right?? Is it pressed on like most cars??
Any other tips I should know about?? If any, it would be greatly appreciated. Thanks in advance.
Apr 25, 2009 at 12:19 AM
BILLYMAC
  • 2,204 POSTS
hi. no the pulley bolts to the belt drive .so once you remove the bolt on the pulley it will fall to the ground...line timeing marks mark with white paint or something you can see well.. be sure belt is tight roll eng around by hand two turns ..after new belt is on. recheck timeing recheck tension. do not start car until crank pulley is reinstalled. good luck billymac
Apr 25, 2009 at 8:13 AM
IRFMAN2000
  • 32 POSTS
[quote:094e169453="billymac"]hi. no the pulley bolts to the belt drive .so once you remove the bolt on the pulley it will fall to the ground...line timeing marks mark with white paint or something you can see well.. be sure belt is tight roll eng around by hand two turns ..after new belt is on. recheck timeing recheck tension. do not start car until crank pulley is reinstalled. good luck billymac[/quote:094e169453]
Oh thanks man. Yea I took the pulley off and fell right to the ground and I removed it with an impact wrench to it wont throw off the timing.
But thats besides the point lol. It took me 10 hrs to do the job from 9am until 730pm or so. I got set back 2 and a half hrs becuase after I got the belt on, I put on the serpentine belt and tensioner not putting anything else back together yet. I started it after of course putting crank pulley back on and the water pump started leaking. Turns out I put the gasket on backwards.
so this is where the 2 hr set back came into play, by the time I took off the pump and ran to 2 autozones becuase one didnt have the water pump gasket so I had to drive to another one on the other side of town. Got back and got the old pump and made sure 5 times on this is how the gasket goes on so I put it on as well as the pump and everything was lined put and put the belt on and everything stayed in line.
The first time I put the belt on, the crank kept jumping a tooth so I had to keep taking off the belt and keep lining up the crank and I finally did after like 10 tries. You gotta remember this is my 1st time ever doing a timing belt. Hopefully next time on another escort I do for somebody it wont be as bad.
Well I said I was gonna let you know how it goes and 3 mos later here I am. I'm so glad I saved myself like $400 labor. I've only paid 130 in parts that included the belt, tensioner, crankshaft seal, and water pump.
I was so frustrated earlier and kept thinking to myself wtf was I thinking about doing this. But not I got it done, i'll do it again. I was outside alllllllll day in 85 degree weather nonstop, and i'm sooooo whipped right now. I think i'm going to bed.
I also want to thank everybody for giving me the confidence to do this job. If it werent for you guys I wouldve taken it in. LIke I said it wasnt as painful as I thought.
Ok sorry for the longggg story and I hope everybody has a good night and I know Ill sleep very well tonight.
Apr 25, 2009 at 9:50 PM
