1999 Ford Escort Springy Brake sound
1999 FORD ESCORT
JANETLEEBURKE
  • 4 POSTS
Brakes problem
1999 Ford Escort Engine Size unknown Front Wheel Drive Automatic 191000 miles
We have 1999 Ford Escort Wagon the Brake seem to have sringy sound when stepping on the Brake pedal.What could cause this problem and what can we do to correct this problem? Plea let me know. Janet Burke Email: [email protected]
Mar 20, 2008 at 7:31 AM
MERLIN2021
  • 17,250 POSTS
If the sound comes from the pedal are, put some white lube on the pivot, were the switch is, if it's from the back brakes, remove the drums, and inspect...you need to either clean and adjust or replace them...if you replace, remeber to lube the backing plate, and use NEW hardware...
Mar 20, 2008 at 7:40 AM
