1999 Ford Escort NO REVERSE
1999 FORD ESCORT
FOURX4
Transmission problem
1999 Ford Escort Two Wheel Drive Automatic
Install a used Transmission in a 1999 escort shifted Ok for one day now has no reverse.
code set are PO750 PO713 PO755 PO760 P1506
Nov 5, 2009 at 4:43 PM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated You could have low fluid level, a faulty/wrong Transimission range switch fitted or it could be a fault inside the transmission !! No Reverse, Forward Gears Okay Fluid level and condition, shift linkage, low line pressure, valve body, incorrectly tightened valve body bolts (cross-leaks), 1-2 shift valve, Neutral-Reverse accumulator, pump assembly, reverse clutch and low/reverse clutch. hope this helps
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_210.png
Nov 6, 2009 at 3:54 AM
