No Power To Fuel Pump?
1999 FORD ESCORT
150,000 MILES • 4 CYL • FWD • MANUAL
CKWORLEY
Turned a corner in our escort and lost power then the engine died. We replaced the fuel pump and fuel filter. The car acts like it wants to start but is getting no fuel. Upon checking there is no voltage to the fuel pump. We have checked all the fuses and reset the fuel shutoff valve. There is no pressure to the fuel rail. Do you have any ideas?
Jun 29, 2008 at 9:17 PM
BMRFIXIT
  • 19,053 POSTS
Check fuel pump relay which is called a constant control relay unit. here is the location so you can swap it out to help fix the problem. Check out the images (Below). Please let us know if you need anything else to get the problem fixed.
Jun 30, 2008 at 6:13 AM
BMRFIXIT
  • 19,053 POSTS
https://www.2carpros.com/forum/automotive_pictures/99387_escor_wiring_99_1.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_escor_wiring_99_2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_escort_wiring_99_1.jpg
Jun 30, 2008 at 6:27 AM
