1999 Ford Escort Idle Air Control Valve
1999 FORD ESCORT
153,000 MILES • 4 CYL • 2WD • AUTOMATIC
IRISH75
I used a diagnostic tool to find out why the service engine soon light was on. It gave me P1506, which says it's a IAC system over speed error. What does this mean? Do I need to adjust the idle or do I need to replace the IAC valve altogether?
Mar 6, 2009 at 12:45 PM
DAVE H
  • 13,384 POSTS
20) DTC P1506 This DTC indicates IAC system has reached over speed malfunction. Possible causes are: IAC circuit short to ground. IAC assembly stuck open. Air intake leaks or restrictions. Damaged throttle body. Contaminated or damaged IAC valve assembly. Faulty Powertrain Control Module (PCM). Start engine and allow to idle. Inspect air inlet system any of the following possible faults: Cracked or punctured air inlet tube. Loose inlet air tube or air cleaner housing. Loose or damaged throttle body. Contaminated or damaged IAC valve assembly. Faulty EGR valve or gasket. Faulty PCV valve or hose. Check entire intake air system for vacuum leaks. Repair as necessary.
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_14.png
Mar 6, 2009 at 12:54 PM
