I have a 1999 Escort ZX2 with 144,000 miles. When driving I have a whining noise that lasts for about 5-10 seconds then quits. When I engage the clutch and rev the engine it quits only to come back seconds later. While trying to trouble shoot the problem I discovered that there is engine compression build-up in the crank case that is released when I unscrew the oil fill cap. I have replaced the PCV valve, PCV valve hose, serpintine belt, idler pulley, several of the worn out vacuum hoses as well as ran a can of Seafoam through the vacuum system. I am at a loss!!
Jul 20, 2010 at 7:41 AM
