Four cylinder front wheel drive automatic.
Hello, I am working on a air conditioning system that the compressor will not come on. I fixed a broken wire going to the compressor, fuse is good. Voltage at that plug varies from 4 to 11 volts. I can jump the compressor with a another source of 12 volts and it will run. I ran it long enough to put in one can of 134a. I found a two wire plug on the accumulator/dryer and checked it for voltage of 13 to 14 volts with the car running. I jumped it across and the cooling fan came on. I found a four wire plug on the high pressure line and decided to stop there because I do not have a repair manual or a schematic to pursue this further. Please advise. Thanks.
Jun 26, 2009 at 10:04 AM
