1999 Ford Escort 100 amp main fuse blows when negative term
1999 FORD ESCORT
80,000 MILES • 4 CYL • FWD • AUTOMATIC
KINGCED83
when i chaged the battery in my 99 ford escort the blue 100 amp main fuse and the 10 amp fuse inside the car keeps blowing ive changed the starter and the alternator and it keeps blowing the fuse and there 13.00 dollars a piece and ive blown three of them. and i noticed that one cable from the positive terminal is connected at the firewall and the same cable is connected to a brcket on the starter but is not connected to the starter
Apr 13, 2009 at 3:19 PM
MERLIN2021
  • 17,250 POSTS
Are you sure you are hooking the cable to the right battery posts? Main fuse will blow if you hook em up backwards.
Apr 13, 2009 at 3:51 PM
KINGCED83
yes the post were hooked up right although the battery that walmart sold me the post were on the opposite side of the battery and i had to take it back and get a new one after that the fuses started blowing
Apr 14, 2009 at 1:22 AM
MERLIN2021
  • 17,250 POSTS
Ok so the first replacement battery worked, but the posts were on the wrong side? Second battery has a problem with blowing the main fuse? Try a known good battery, with the right specs for your car.
Apr 14, 2009 at 12:47 PM
