My fuel pump is not working. I've checked everything I could. The car has about 10 volts through the inertia switch to a fuel pump driver module. There is no output to the fuel pump. The driver module has been replaced and still no go. The fuel pump has only 5 ohms of resistance and one that I've checked at a junk yard out of the same car has 30. I don't know if the fuel pump is possibly bad and shorted out both driver modules. If I jump battery voltage to the fuel pump the car starts. I'm pretty sure that the relay and other components in the system are good. Any ideas where to go from here? I know the dealership won't sell you the fuel pump without the driver module. They come as a unit. I don't know why but I think it may be because of the problem I am having.
Apr 6, 2007 at 7:34 PM
