Hi there,
There are a number of variables in setting the steering geometry. When doing an alignment (as i was taught in the dim dark days) You first checked all steering and suspension components, tyres and wheel bearings. We would centre the steering wheel and start the alignment check. Today most operators just bung on the alignment heads and hope for the best. If your car is tracking well, but the steering wheel is of centre, you can re centre the steering wheel, it is on a splined shaft and you will be able to come back to centre. (If you have air bags, don't do it your self. You can have the track re set if you wish, but a full alignment check would be advised. It all goes back to doing the alignment correctly in the first place.
Mark (mhpautos)
Jan 20, 2008 at 4:29 AM
