I have a 98 ford escort with 4 cylinder single cam engine.My issue is my speedometer,if I try and turn on the cruise control the speedometer will quit working.
It may stop working for an hour or so,or for good.My speedometer stop working for the first time when the cruise was on.It went 6,or 7 months without working then one day it started working.
It worked for a week or so then stopped on it's own.Over the period of two years it worked a couple times for a day or so but would always stop.
I just had to replace the head gasket so I had the repair guy replace the sensor with the gear on the transmission.
When I got the car back last week the speedometer worked.Today while taking a hour drive I went to engage the cruise control and what do you know the speedometer quit working again.
After going in the store to shop for an hour when on the drive back home it started working again.After I got home an hour or so later I went somewhere and it was working.About mid trip the speedometer stopped for about 5 seconds and started working again.
The speedometer was having no issue after i got it back from repair until I tried the cruise for the first time.The fact that it works,and didn't mess up until I tried the cruise tells me it's not the sensor,but the cruise messing up the speedometer.
I can live without the cruise control,but the speedometer I need to work.Any idea's what the problem sounds like? Has anyone ever had an issue like this before?
If there is a way to disconnect the cruise control if that is the issue to make the speedometer work for good i'am all for it.
I'am just sick thinking about it,because I know now the speedometer will be on and off again now,but would have been fine if I never tried the cruise.PLEASE help,thanks
Mar 10, 2009 at 10:18 PM
