The cars started running rough and then one day it stopped we replaced the plugs and wires and the Idle air control valve. The mechanic checked everything and he doesnt know what it is. we had a mechanic check the computer and he said it doesnt show anything wrong. He said it might be the computer is not sending the correct info. It does not run when the map connector is connected but does when it is not disconnected. The mechanic changed it out with another map and it did the same thing.
Jan 24, 2010 at 7:19 PM
