1998 Ford Escort License Plate Light
1998 FORD ESCORT
109,000 MILES • 4 CYL • FWD • AUTOMATIC
TONYA_1518
  • 8 POSTS
I have a big problem with my license plate light fixture. When trying to replace the 2 burned out light bulbs it was discovered that the entire fixture is totally corroded and fried ( on both lights). How can I fix this myself? Is there a way I can geri-rig a small light fixture in place of it or replace the original ( hopefully with instructions)?
Thank you in advance!
Dec 14, 2008 at 4:58 PM
BMRFIXIT
  • 19,053 POSTS
Try and drill it out
find a replacement that will fit
Dec 14, 2008 at 8:27 PM
ZACKMAN
  • 4,202 POSTS
Rather than trying to rig a different fixture, consider one from another Escort. There plenty of 97 - 2000 Escorts at the wrecking yard. Just go in and get a couple of entire assemblies. Just remove the two screws and plug in the connector, you're don
Dec 14, 2008 at 9:13 PM
TONYA_1518
  • 8 POSTS
[quote:af7236d2e5="tonya_1518"]Electrical problem
1998 Ford Escort 4 cyl Front Wheel Drive Automatic 109000 miles
Thank you in advance![/quote:af7236d2e5]
Thank you, thank you so much! I appreciate your help with this. I will give it a try!
Tonya
Dec 15, 2008 at 7:35 PM
JAMES W.
  • 2,394 POSTS
Just wondering if we were able to help you with your light problem. You needn't respond if everything is ok.
Dec 20, 2008 at 5:32 PM
TONYA_1518
  • 8 POSTS
[quote:e1b97f35e5="Zackman"]Rather than trying to rig a different fixture, consider one from another Escort. There plenty of 97 - 2000 Escorts at the wrecking yard. Just go in and get a couple of entire assemblies. Just remove the two screws and plug in the connector, you're don[/quote:e1b97f35e5]
Well, no luck there so far. I called around to all the salvage yards and no one had any. I am still out of luck.......but I was wondering about your answer and need a little more clairification. You say to "Just remove the two screws and plug in the connector, you're don" where are these 2 screws located at? I don't know what I am looking for. Are these way up under the trunk? How far to reach to get to them? Am I needing to also replace the wiring assembly ? I don't know if the wire assembly is bad too. All I know is the 2 light bulb fixtures are bad.
One of the guys at the salvage yards said I needed the housing for it but didnt say if the wire assembly came with it or what.
Please help! I can't drive my car after dark because of this and I am risking a ticket.
Thank you!
Dec 22, 2008 at 4:24 PM
TONYA_1518
  • 8 POSTS
[quote:46c22a7b78="James R. Weizel"]Just wondering if we were able to help you with your light problem. You needn't respond if everything is ok.[/quote:46c22a7b78]
Thank you for your reply and concern. I haven't had any luck with this. I left another post here below. I hope someone can help me find another fixture for my license plate light.
Thanks again
Dec 22, 2008 at 4:28 PM
IMPALASS
  • 3,112 POSTS
Hello - Which one of the pics are you needing.....Pic 1 or Pic 2
https://www.2carpros.com/forum/automotive_pictures/248015_Picture1_41.jpg
https://www.2carpros.com/forum/automotive_pictures/248015_Picture2_31.jpg
Dec 28, 2008 at 9:55 PM
TONYA_1518
  • 8 POSTS
Oh wow thats nice for you to display a pic. Its more like PIC 2. Would a 1997 or 2000 model work? I hope to hear from this soon, Thanks so much for your help, I appreciate this so much! Tonya
Jan 2, 2009 at 7:03 PM
IMPALASS
  • 3,112 POSTS
Hello –
By the pics I see – it looks like a 1997 or 2000 is the same. To be sure you can contact the parts department at the dealer and ask them if the part numbers are the same for a 1997 and 2000 as the 1998…..if they are you are in.
Jan 2, 2009 at 8:39 PM
TONYA_1518
  • 8 POSTS
Thank you for your info. I will check with the dealership about that. I guess they designed this car poorly because I have never seen a car where the license plate assembly gets toasted,most likely from water getting down into the fixture. IMHO this should never happen.
As for the manual, I am laid off at the present time and cannot afford it. Thats why I am here, hoping to get information at a lower cost. Thank you for the offer anyway.
"Your welcome" on the donation
Tonya
Jan 3, 2009 at 11:31 AM
IMPALASS
  • 3,112 POSTS
Hello –
You would be surprised how some cars are. It just happens.
No worries about the manual…..I put that there as a suggestion for folks……..
Sorry you are laid off……good luck on finding a job…….
Have a great day.
Thank you very much for the donation
Please let us know if what the final fix was for your car so we can better assist others. Thanks!
Find a car repair manual for your car repair questions.
Jan 3, 2009 at 2:17 PM
TONYA_1518
  • 8 POSTS
Hi all, Well I finally am getting it fixed and it looks like for only $ 8.00 !!
I took it to an auto supply store and they looked at it and pulled the old bulbs that were stuck inside there out and I put in the new bulbs and got one of the lights working. He told me I needed the housing for the one that didn't work and they didn't carry it so I called Ford dealership and they said the housing actually comes with the socket and wire, so I ordered 1. I am going to take it to my brothers and have him install it for me, so In all, this only cost me a small amount compared to what I thought it was going to cost me.!!
I want to thank all of you who helped me with this and I will come back here when and if I have any more car problems. I just love this site and happy its here. You've all been great!
Thank you!
Tonya
Jan 5, 2009 at 4:18 PM
IMPALASS
  • 3,112 POSTS
Tonya
Glad to hear your car is going to be fixed for minimal costs………
We are glad you appreciate the website………..come back anytime…you have a lot of great folks waiting to do what they can to help you out.
Good luck with job hunting and the New Year!
Jan 5, 2009 at 7:24 PM
