[quote:e1b97f35e5="Zackman"]Rather than trying to rig a different fixture, consider one from another Escort. There plenty of 97 - 2000 Escorts at the wrecking yard. Just go in and get a couple of entire assemblies. Just remove the two screws and plug in the connector, you're don[/quote:e1b97f35e5]
Well, no luck there so far. I called around to all the salvage yards and no one had any. I am still out of luck.......but I was wondering about your answer and need a little more clairification. You say to "Just remove the two screws and plug in the connector, you're don" where are these 2 screws located at? I don't know what I am looking for. Are these way up under the trunk? How far to reach to get to them? Am I needing to also replace the wiring assembly ? I don't know if the wire assembly is bad too. All I know is the 2 light bulb fixtures are bad.
One of the guys at the salvage yards said I needed the housing for it but didnt say if the wire assembly came with it or what.
Please help! I can't drive my car after dark because of this and I am risking a ticket.
Thank you!
Dec 22, 2008 at 4:24 PM
