1998 Ford Escort front disk rotors
1998 FORD ESCORT
238,000 MILES • 4 CYL • FWD • AUTOMATIC
RVARGAS
i cannot remove the disk rotors to replace them.does my car require that i remove the large wheel bearing nut first? icould swear i replaced them a few years ago and never had to remove the large wheel nut.
if they come off qithout removing the nut what do i use to loosen the rotors , can i use a heat torch?
Mar 15, 2009 at 6:06 PM
ZACKMAN
  • 4,202 POSTS
Don't need to remove the axle nut. The rotor is simply "frozen" from rust and other road contaminants. Go to your local parts store and ask for PB Blaster. Spray it on the lug bolts and axle nut.
https://www.2carpros.com/forum/automotive_pictures/55316_98escortrotor_1.jpg
Wait 5 minutes, and then tap the rotor with a rubber mallet. It will come out.
Mar 17, 2009 at 11:17 PM
