1998 Ford Escort cooling fan wont come on
1998 FORD ESCORT
80,000 MILES • 4 CYL • FWD • AUTOMATIC
RKAHLE
i checked the fan and it good,has good 40 amp,still wont come on
Sep 6, 2010 at 7:39 AM
Check and test the engne coolant temperature sensor/gauge sender switch
Jun 6, 2020 at 12:46 PM
RKAHLE
ok changed the unit pulled the fan assy and checked it fan works if i hot wire it,but not with how it should be working.
Check the fan relay in the CCRM if okay test the engine coolant temperature sensor/gauge switch
https://www.2carpros.com/forum/automotive_pictures/12900_f1_28.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_f2_24.jpg
RKAHLE
how do you check a ccrm??????????
If the coolant temperature sensor/switch is okay the problem could be the CCRM or the computer itself
