1998 Ford Escort Check Engine Light
1998 FORD ESCORT
190,000 MILES • 4 CYL • FWD • AUTOMATIC
THOMPSONM2
  • 4 POSTS
Hi, I have a question about the check engine light on my 98 ford escort(with 190000 miles.) Before I had the work done, the check engine was on. I had the code checked and it pulled a code stating that the egr flow intake was insufficent. I had a full tune up, front wheel alightment, and the intake repaired(apparently there was a hose or tube that was bent and pressed against the engine.). However a couple of hours later, the light came back on. The car is running alot better than before I did the repair work, I'm not sure why the light came back on. Thank you.
Mar 13, 2008 at 9:13 PM
Get the computer rescanned for OBD2 code/s and comeback with it-it might not be the same one. This is where we start the diagnosis.
Mar 14, 2008 at 2:35 AM
