1998 Ford Escort check coolant light
1998 FORD ESCORT
155,000 MILES • 4 CYL • FWD • AUTOMATIC
CLINGENPEEL3
Check coolant light comes on every morning when car is first started and sometimes throughout the day. What could cause this as I have checked the fluid level which is good.
Nov 29, 2008 at 9:12 PM
DSPLC
  • 220 POSTS
If the coolant reservor (beside the passenger side fender) is full . Unhook the electrical wire connection on the coolant reservoir. Does the check coolant light still turns on when you start it. If it does not light on, then you need a new low coolant warning sensor attached to your coolant reservoir.
Nov 29, 2008 at 10:18 PM
