1998 Ford Escort Blower Motor will not run
1998 FORD ESCORT
125,000 MILES • 4 CYL • FWD • AUTOMATIC
DONNIECAR
I have a problem with the blower motor not running, there is 12 volts present at the end of the wiring harness that goes to the blower motor, the blower motot is not the problem as i have already tried replacing that. It does not matter if heat or cool is selected from the switch or does it matter if the control switch is on low or high speed. Any help would be appreciated. Thanks, Donald
May 22, 2010 at 4:02 PM
Check and test the blower motor relay and the resistor
May 22, 2010 at 6:21 PM
DONNIECAR
Could It be the switch? I checked the relay and it was fine. I have not checked the resistor yet. Thanks
May 22, 2010 at 9:53 PM
Could very well be the blower switch too-test it
May 22, 2010 at 9:57 PM
