1997 Frod Escort LX--name of part
1997 FORD ESCORT
CARL F
The flexible vacuum hose at the top of the fuel pressure regulator connects to a small plastic cylinder. What is that cylinder called? I need to replace the part because the small protuberance over which the vacuum hose (from the fuel pressure regulator) fits is cracked.
Thanks!
Sep 2, 2007 at 1:26 PM
DSPLC
  • 220 POSTS
Is this the one???
https://www.2carpros.com/forum/automotive_pictures/89255_cylinder_2.jpg
Sep 2, 2007 at 2:56 PM
CARL F
Is this the one???
Hi--thanks for the reply. My part looks different, though it may serve the same function. The cylinder is black plastic and about 2" long and maybe 3/4" diameter. A small vacuum hose from the top of the fuel pressure regulator attaches to the part via a small nipple. Two larger hoses are attached to the other side of the part.
Sep 3, 2007 at 1:21 PM
DSPLC
  • 220 POSTS
Your right , it is not the fuel delivery module. Sorry, I could not find that part in the Ford Escort Factory Manual. It just says plastic tube.
If you go to the Ford dealer, they have a schematic diagram of the engine. Just look for the plastic tube that connects to the fuel pressure regulator, to the intake manifold, to the main vacuum line.
Sep 3, 2007 at 3:33 PM
CARL F
That sounds good--thanks for the assistance.
Sep 3, 2007 at 4:16 PM
