This car recently had new muffler installed. Sluggishness from dead stop noted shortly after along with what almost sounds like an exhaust leak in the front end - returned to shop and no leaks found. Once up to highway speed, car runs fine, however once warm the car idles rough (surging) when at a stop. Turning the A/C ON cures this problem so long as the fan runs (30 seconds). When the fan shuts off, rough idle returns. This rough idle sounds like a cycling 1 second surge in RPM. rrrrrunh, rrrrrunh, rrrrrunh
New plugs, wires, fuel filter, PCV, serpentine belt installed. Sluggish acceleration improved, but could be better. Rough idle after warm-up continues.
Temp gauge flaky, accurate when working, but cuts in and out. Seems to be affected by acceleration and shifting between gears. Either reads correctly or not at all. This is a fairly constant state, IOW it fluctuates every few seconds rather than minutes or days.
Sep 29, 2009 at 12:14 PM
