Drive Train Axles Bearings problem
1997 Ford Escort 4 cyl Front Wheel Drive Automatic
This vehicle has 190,000 miles but is still in relatively good condition. The L/F CV shaft has failed, with part of the inner CV joint (the bearing cup) and the shaft still in the transmission. The clip on the shaft refuses to release. I have followed repair manual instructions and removed both the cross member and the ball joint to allow moving the strut out of the way.
The heavy duty pry bars I purchased will not do the trick. I drilled the cup on two sides, installed bolts, and have tried a slide hammer. Nothing seems to work. I have tried with the transmission both in park and in neutral, plus had someone help me slowly rotating the R/F wheel assembly slowly as I hammered. No luck!
Help! I refuse to give up but at this point I am completely out of ideas! I would tow the vehicle to a garage, but I'm not sure what they could do that I haven't done. Your suggestions - Please . . .
Signed: Frustrated Grady
Sep 4, 2010 at 12:07 PM
