Is it not true that if one has a leaking rear main seal, the oil will leak out even when the engine is off? I have very slow oil leak showing up right at where the oil pan is bolted to the transaxle. I've already changed the valve cover gaskest, as I had a mnor leak there. The oil dosen't appear to trail down the side of the flywheel housing, so I don't think it's the head gasket.
Jul 24, 2009 at 2:38 PM
