1997 Ford Escort Code P0302
1997 FORD ESCORT
14,100 MILES • 4 CYL • 2WD • AUTOMATIC
AFG2001
Service Engine Soon (SES) light came on; had electrical reading done, problem code was P0302. I replaced the spark plugs, PCV valve and the ignition coil. SES Light was out, due to battery disconnect, after about 50 miles on the road, it came on again, this time flashing, turned solid for about 5 minutes, flashing, turned solid again.
I tested the spark plugs and the wires; tests were all SAT. At this point, I'm not sure what to do; I'm weary of taking it to a local shop (I'm active duty stationed overseas in Italy and have heard horror stories of price gouging, faulty repairs (or having to get different repairs done after maintenance), etc. Even from the place on base. Can you recommend anything? Thank you!
Sep 5, 2008 at 4:46 PM
MERLIN2021
  • 17,250 POSTS
Chech the resistance of the injector, should be 11-18 ohms.
Sep 5, 2008 at 4:54 PM
