1997 Ford Escort
1997 FORD ESCORT
81,000 MILES • 4 CYL • FWD • AUTOMATIC
TOOFLACA
i hear a ticking noise from the passenger side. i've replaced the u spring on the front right caliper and it stopped for a few days and now it's back but the spring is still good
Aug 1, 2010 at 10:45 PM
Does it happen all the time or just when turning? Also, does it change with the vehicle speed?
Aug 1, 2010 at 11:59 PM
TOOFLACA
it gets louder the faster i go. i don't think it is the cv boot because it doesn't make that clunking noise when i turn. should i check the rear brakes or do i not have any?
Aug 2, 2010 at 7:29 PM
If it stopped when you replaced the brake parts and is making the same noise again, check to make sure everything is tight including the calipers.
Aug 3, 2010 at 1:10 AM
TOOFLACA
will do. thank you. if the problem persists i will contact you again. great services, i am recommending this site to friends and family.
Aug 3, 2010 at 8:40 PM
You're welcome. Let me know what you find. And thanks for recommending us. Tell as many people as you can.
Aug 4, 2010 at 12:12 AM
