1997 Ford Escort
1997 FORD ESCORT
RALPHD
Engine Mechanical problem
1997 Ford Escort 4 cyl Two Wheel Drive Automatic
I'm trying to get my 97 escort to start. how can i check the timing with out removing the crankshaft pulley? there is a spark and i smell fuel when turning the engine. I'm thinking that the timing is out. also what purpose does the crankshaft sensor serve?
Feb 3, 2009 at 3:12 PM
BMRFIXIT
  • 19,053 POSTS
click the link and check the timing marks
https://www.2carpros.com/car_repair_information/tec_info/1997/ford/escort/1997_ford_escort_timing_belt_diagram_marks.htm
remove timing cover and check if yours the same they should if not need to remove and replace timing belts
check fuel pressure too
Feb 3, 2009 at 6:47 PM
