1996 Ford Escort Throttle Body Vacuum Hose
1996 FORD ESCORT
11,600 MILES • 4 CYL • FWD • MANUAL
DISCUS11
I just replaced my 1.9L engine with a remanufactured one. Before I removed the original engine, I labeled all the electrical and vacuum connections with masking tape and numbered them for reassembly. Problem I have is that a 1/4" vacuum line coming off bottom of throttle body has its label missing and I can't see any viable connection that is its mate. Hose length is about 10", and no open connections exist within swing radius of hose. Can you provide some assistance?
Mike Farago
Feb 13, 2009 at 2:56 PM
IMPALASS
  • 3,112 POSTS
Hi Mike I have attached the only info I have for the vacuum routing. On the TB removal and installation it just says to remove it but doesn't tell where it goes.
https://www.2carpros.com/forum/automotive_pictures/248015_Picture2_40.jpg
You did t he swing radius - that is good but try it again and I am sure you did but remember it may only be 5 inches away and the other 5 is for slack. You might also check a car lot that has a 1996 Escort and pop the hood.......I have done that before.........
Feb 13, 2009 at 3:43 PM
