1996 Ford Escort overheating due to fan not coming on
1996 FORD ESCORT
135,000 MILES • 4 CYL • FWD • AUTOMATIC
WVRAY
  • 6 POSTS
I have replaced the ECT sensor and tested the fan(which is working on both speeds). What else can I replace to correct this problem? Had a new radiator installed about 3 months ago due to a leak.
Thanks,
WVRay
Jul 13, 2009 at 1:15 PM
LAZYGAZER
  • 68 POSTS
Have you checked the relay?There are 2 relays on the fender wall behind the air cleaner assy. remove the assy to access them then check them to see if they are working correctly if so the computer has to be replaced.
Jul 31, 2009 at 11:55 PM
